y1 shift for
HI. i got a “y1” crx tranny for my 90 ls and i was going to swap it on this weekend or so but i have realized that it has no shift release fork. the one that sits behind the release bearing`everything else is there spring bolt and all. but no release fork. now i am trying to find a replacement and all the scrapyards here are cleaned as far as honda goes as soon as they get 1. does any1 know where i can source a release fork for a crx y1 trans. does any1 know if any other shift forks will work off of other cable transmissions
I just searched some part numbers and it looks like the cable ls and gsr use the same clutch release fork. The hydraulic release fork in the civic sir, del sol, integra ls, gsr, type r & crv all have the same part number. From that Id say all b series cable release forks are 22821-PH8-010 and all hydraulic ones are 22821-P80-010. Hope this helps.
