Even the “long” geared YS1 on non-VTEC motors is still longer than the Y1 isn’t it? Which will make it better for high way driving.
Just curious because I’m trying to decide which transmission I plan on using when I swap in either a CTR or GSR motor. My car will also be mostly used on the highway.
[QUOTE=ABCVTEC;1677762]Even the “long” geared YS1 on non-VTEC motors is still longer than the Y1 isn’t it? Which will make it better for high way driving.
Just curious because I’m trying to decide which transmission I plan on using when I swap in either a CTR or GSR motor. My car will also be mostly used on the highway.[/QUOTE]
You could do that, but i wouldnt recommend taking that route. I had that done on my short geared ys1. Going from 4th to a long geared 5th can cause some damage to the tranny in the long run. I started to notice some grinds shifting into gears a few weeks later. So i switched it back.
