Yellow Fogs
I have a set of ebay black housing headlights and i want to make the fog part yellow like the actual JDM Headlights. How do I do this without changing to a yellow bulb. I know how to remove the lens. Im just not sure what material would be best for making the fog reflector yellow and still reflect well.
you have to us the yellow fog light capsule (im sure there are some g2ic member here that are selling those). if you know how to take apart the lens, i suggest you do that in order to get to the fog light reflectors. in order to make the capsule fit, you have to enlarge the bulb hole on the reflector. be careful not to brake the capsule because it’s made out of glass and cracks VERY easily.
My buddy has those headlights, he actually put in 3k HID kit in it and god damm it look sexy ass hell. and 3k gives you that deep yellow look . . .
I was thinking about doing 3k with the high and low beams.
Not for driving lights. For the fog lights.
I’m aware. I"m giving thought to doing the headlights too
since the fog light bulbs on the ebay headlight enters the reflectors from the top, having the high/low beam HID bulbs won’t make a difference, i tested it already using the dual bulb HIDS and bi-xenon HID. all you see is the light slightly flickering. you can’t even tell if you are in high beam or low beam. just stick with the basic HID.
Thanks for the heads up
