Yonaka and Function & Form Type 1 Coilover Fix
For those of you who have either, Function and Form sells an extended rear mount that way you can raise the rear end higher than tucking tires (LOL). They also fit Yonaka coilovers! This will take you from only being able to tuck tire at highest setting, so tucking tire at the lowest setting. Here’s some pictures comparing the sizes and installed.
nice find… i know a lot of people have this problem…
how much was it?
i knew it! i said they were the same
Haha I know Bryan I just wanted to give a clear answer.
The tubes are $25/ea and it was $20 shipping for me and I’m in Alabama. It may be different if you are farther away. You have to call as they are not listed on the site
damn, i was told that the ef and da ones were the same so i bought some for my ef but sold that and i was going to put them on my da but noticed that the rears were way to short so i sold them for $475 and they were brand new :frowning: if i would have known that all the needed was the extended piece i would have kept them :frowning:
Any idea if these will fit D2 coilovers and where to order from?
Now if they would only come out with a little longer ones for the front to utilize all the space on the front since only way to slam front on yonakas or function 1’s is to lower the spindle down messing up the spring rate
I just put these on my car, sooooo much happier with my ride height. I called Function Form directly, they ended up being $75with shipping
