i read in a post before that DA with abs is not compadeble with z 10 or other traction bars. is this true?
huh wonder if it fits because I drive a db2 and yes every db2 has abs…
the Z10 and Full Race crossmembers do not have the mounting plates for the ABS modulator and pump. you either have the choice of using the old oem one and figuring out a way to make it mount to either crossmember or simply deleting those pieces of the ABS. only things you will need is a fitting to plug off the line and a hose end cap for the other line. both of which can be bought at your local kragen/autozone/pep boys for about 5 bucks… thats what i did.
thx. also would it be a problem if i have a civic rad?
Just remove the bracket from the old crossmember, and weld ( or have someone weld ) on some u-bolts and clamp it to the bar. Thats what I did.
Vteczen can you show me some pic’s of your abs still on the after market crossmember???
THankyou
