I haven’t seen an upgrade guide yet for the S2K caliper/RSX-S rotor combo yet so I thought that I would put one together.
Fronts
Tools needed - 14mm socket, 17mm socket, needle nose vise grips, old fuel line, screwdriver wrench, bottle of brake fluid.
1st - You are going to need front calipers from a 02 and up S2000. I sourced mine from ebay. Front and rears for 149 shipped.
2nd - 11.8" Front rotors from an 02 and up RSX type S re-drilled to 4x100
3rd - You have a couple options to correct the rotor offset. It is 3mm off center for the caliper to work correctly.
Option 1 - Take your caliper brackets to a machine shop to have them mill 3mm off the side that contacts the hub. This will push the caliper back further and allow the rotors to be correctly aligned.
Option 2 - This is the way that I did mine. Take a 3mm wheel spacer and cut it to fit inside of the rotor. This will go between the hub and the rotor and push the rotor further out for the same desired effect.
If you use option 2 then it becomes a completely bolt on affair.
Disassemble
Use needle nose vise grips with old fuel hose on the teeth so they don’t damage the brake line hoses and pinch the line closed as close as you can to the caliper with enough room to take the bolt from the brake line to the caliper off. (This will save you much brake bleeding later on)
Remove 14mm bolt from the brake line to the caliper and set aside. Make sure to do this first because it’s much harder taking it off after the caliper is removed.
Remove the 2 17mm bolts holding the caliper to the hub.
Discard old caliper.
Use the screwdriver wrench to take out the rotor screws (sometimes they can be a PITA if you don’t have this tool)
Take off the old rotor.
Reassemble
Put the trimmed wheel spacer on the hub first. The lug bolts will hold them in place.
Put your new 11.8" rotor on.
Attach the new S2K calipers to the hub.
Bolt the brake line back to the caliper. Don’t forget the solid washers on both sides of the bolt attaching the brake line to the caliper.
Have a helper assist in bleeding the new calipers. Don’t forget to keep topping off the reservoir while bleeding.
Enjoy
Before
After
Rears to come next weekend.
