16 g Dsm turbo on my DA
Well I talked to them today they switched it and are gonna ship me the 14b kit. Idk I guess I have a 14b oh well still gonna do justice on an Ls… I didnt kno much about turbos when I got it… Most people I talked to about turbo said they had eclipses wit a tdo4 turbo and i just have maybe a tdo5 and it was ported and the fins were clipped. Heres a pic.
you are gunna have a really fast spool!
i have a tdo5h mitsu turbo that i rebuit but no longer use cause it was too small for me…
but its a great street turbo for the price
as for the oil line kit u may just have to get some plumbing off of one of those websites or go to ace hardware w/ your turbo and see which fittings will work… and then u could fab up the stock ones to work with it
why you say very fast spool. Im not lookin for high hp numbers now i just wanna get in the turbo game.
He says very fast spool because it’s a small turbo. I have 10 psi by 3500 on my 14b.
However, there is still the possibility that yours is a 16g. If you look around for pics you will see that the housings are identical. The only difference is the wheels. I believe that the TD04 maybe is the T25 that came is the 2nd gen DSM’s, I’m not sure though. I do know that the 14b and 16g are both TD05 and have the same housings. So you may really have a 16g, but either way the same oil fittings will work.
Ok good I kno that I deff do not have a 16g wheel cuz the blades being equally spaced but you know but any chance by looking at it if its any diff then the 14b wheel you have? I kno this turbo spooled so hard on the laser it was off of… it hit 16psi by 4000. It pulled hard as hell. Taking out 8cyls and most other turbo cars in the pretty close to stock laser. Had 2.5 inch exhaust b.o.v and boost controller
you have to remember boost does not make power, CFM does, that little turbo just wont push the CFM a larger one can. so your power at 10psi on that turbo will be much different than the power of a T3 or T3/T4 at the same boost pressure, not saying this is bad, but dont expect to get much more than about 220whp outta that thing.
My car isn’t with me right now, so unfortunately I can’t take a look for you. If you don’t think it’s a 16g, and it came off of a laser, then it is almost definitely a 14b. Not a bad starter turbo for our cars, and decent power. I’m happy with mine for right now.
I just wanted to get into the turbo game… Ill be upgrading shortly but i gotta start buildin a motor for that. Im not lookin for any hi gains but whatever Im sure ill be happy for now.
