Hi guys, long time lurker, first time posting. I have owned 5 DAs in my day, 3 b18 and 2 b20s. I have run across some extra money with taxes and decided to turbo my B20 swap. I have been around cars for a long time but have only one 1 turbo’d car, a mk4 GTI. I have a few questions that I have tried searching for and haven’t really got a clear answer on. So, sorry for the noob questions but I tried looking.
I have a t3/t4 .57 trim .63ar exhaust mounted to a blox manifold. I am running into fitment issues. I read that some modding to the casting on the block is an option. The other option i saw was a half radiator from say a civic. I was wondering what has worked best for these turbo setups.
hitting on casting.
hitting on radiator.
I have read and googled and asked many people but I still dont understand the oil lines INTO the turbo. My turbo has 2 of the openings just like the one shown. 1 on top and 1 on bottom. Feed and return. I got that part but, I have been told that the feed line and return line should not be the identical. I dont see how this works though. they should have the same flange right? Maybe some detailed pics of oil line setup would help.
2 flanges just like this.
How often do people run into the Tial wastegate being too tall to close the hood off a blox header?
Thanks for all your help in advance
1990 DA9
B20 swap
Brian Crower Cams
Comp Clutch
H&K Lowering Springs
Konig B-Bombs15X7
Toyo T1R tires
Front and rear lower sway bars
Chipped ECU with a Chrome basemap
OBD0-OBD1
450cc bluetop injectors
Godspeed Intercooler
Blox turbo Manifold
57 trim turbo with .63ar exhaust
Walbro 255 fuel pump
Greddy BOV
Thermal R&D 3inch exhaust
Tial 38mm Wastegate
she looks rough now, but you dont have to look good on the autocross course.
Thanks for all your help and I will keep you posted on progress.
