Got it with a set from ebay $73 http://www.ebay.com/itm/191186388534?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
To Do List
- Temporary Alignment
- Stripped Spark Plug
- Battery
- Timing
- Alignment
- Smog
Temporary Alignment
Update On The Lower Ball Joint
If you have ABS don’t get the ball joints with grease fittings
Had to shave axle to fit them
Everything else looks good
Will be double checking the mechanical timing marks
To Do List:
2. Stripped Spark Plug
3. Battery
4. Timing
5. Alignment
6. Smog
Spark Plug Problem Fixed
HTF did you manage to do that?
@mooshie: Too much torque. Good thing it was a cheap fix
To Do List:
3. Battery
4. Timing
5. Alignment
6. Smog
Duralast Battery $110
Replaced small sized battery with correct size
Good News!
Found out the camshaft gears were timed but the timing of the crankshaft wasn’t at tdc
Also thinking about replacing Tensioner/Spring and Bolt
To Do List
- Timing
- Alignment
- Smog
Last Reported: 210,703 Miles
Parts Installed: 210,917 Miles
Well, props for staying busy.
Thanks. Will be posting more pics in a minute.
Timing Belt Tensioner
Removed Tensioner
Don’t even ask lol
Honda Tensioner Bolt (Ebay $11.48)
