3" downpipe
Hi
I have a turbo integra, the problem is my car is lowered around 2" and the 3" downpipe is almost hitting the street just under the oil pan.
Is there any solution to this matter ?
[QUOTE=antx;2234339]Hi
Is there any solution to this matter ?[/QUOTE]
Are you running an open down pipe or a full exhaust?
dont mean to sound like a dick but raise the car up! i had the same problem untill i raised mine up. no mater the size pipe when slammed ur going to scrape…
full exhaust…
You could cut the down pipe to shorten it and replace some length with flex … But to me it sounds like more work than its worth. I would either raise the car a tad, or just live with it and watchout for potholes and bumps.
I decided to make it 2.5"…
Maybe the fabricator can’t get it tucked up underneath there well enough? I run a full 3" turbo back without many problems
