hi,can anyone please refer me to a lnk were i can get a wright up on installing 450cc dsm on a 93 integra ls did a search,thank sorry if i missed it.
thanks also with a 190 walboro pump is that enough for 450cc dsm blue top,or do i need to upgrade to 255. :repost:
thanks again for the help.
Im thinking that it would be sufficient. Look at it this way…i have a stock fuel pump on 9psi with uberdata basemap and dsm 450’s. Works good for me, hardly any detonation. (then again i dont always rag on it)
hardly any detonation!
any detonation is bad
well idk but a stock fuel pump if relly being pushed to its limits with 450cc dsm injectors… id consider up grading if i were you
If i had the cash i would…as far as detonation goes its just under like full boost for a long amount of time in like the higher gears. If i hear it I immeadeatly let off anyway.
190 is PLENTY
what is detonation? lol i dont know
Then maybe you should stop posting in this forum? :stare:
everybody has to start somewhere, not because he doesnt know what detonation is he should stop posting (although he should read a bit more!)
what is the capacity of a stock fuel pump in LPH ?
er… You might wanna find out :giggle:
how do you know if a 190 fuel pump is enough…It doesn matter what amount of boost ur pushing. Its all about the hp your making. Those injectors max out around 300whp or so. get a 255 and at least 550’s if you plan on making some power
All I’m saying is the 450’s will give out way before the 190. I won’t bullshit you with made up numbers but I know this for a fact.
