Hey yall I did some searching around and couldn’t really find what I was looking for… Is a 50mm BOV too big for my goal of 250whp? I couldn’t find anything that said it was, I found some threads about bov’s being too small but that seems like common sense to me… What do you all think?
Only thing i can see being a “problem”, is while shifting between gears on a good pull is loosing to much boost/flow. and having your turbo to spool all that gain agian… but at 250whp i dont think ur going to be going into big boost numbers so shouldnt take long to spool up agian?.. idk… that’s all that i can see maybe being an issue. my 2 cents… if that makes sence.
Yeah you may be right, I didn’t think of that… Thanks for your reply. I think I’m going to go ahead and go with a 50mm bov and see how it works. If I lose boost between shifts or there is some other unforeseen problem I will switch it to a smaller one.
what bov are you talking about in specific?
Tial Q 50mm
i don’t think you’ll have any problem with the tial 50mm, i have the same one on my boosted ls which i’m sure is putting down right around those numbers, never got it on the dyno yet though
Sick. Thanks for your input, Ima order it right now!
