91 rst jg manifold ?'s
i have 91 rs with an r block and gsr head im going to be putting a new jg manifold on. what throttle body should i use, and what happens with all sensors do i not reuse them. im also running p28 ecu hondata setup. can someone give me some tips thanks alot mike
all the stock sensors can be retained and any b-series or h-series throttle body would be fine
throttle body
what would be a better throttle body to go with? thanks mike?
What size is the plenum port?
edelbrock Intake Manifold - 1.8L B18C1 - Natural Finish - Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance and race set-ups, this manifold has four additional bosses for nitrous or added fuel injectors.
edelbrock Intake Manifold - 1.8L B18C1 - Natural Finish - with secondary fuel rail - Performer X manifolds are engineered for street/strip applications where peak torque and horsepower gains are realized between 3000-7800rpm. The larger-than-stock plenum volume and 9" runner length are tuned for producing peak power at high rpm. The Performer X Series manifold is ideal for all-motor and turbo applications.
EDELBROCK Intake Manifold - 1.8L B18C1 - Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance and race set-ups, this manifold has four additional bosses for nitrous or added fuel injectors.
EDELBROCK Intake Manifold - 1.8L B18C1 - Polished Finish - with secondary fuel rail - Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance and race set-ups, this manifold has four additional bosses for nitrous or added fuel injectors.
theres my three options not really sure which to go with any healp on that and which throttle body to go with thanks mike
