Subject says most of it I have a 92 GS with a B16A and I blew the B16A last night. Also my transmission is a JDM S1 tranny and it was already on its way out anyways, the third gear sychros are royally fucked and also sometimes it will fall out of third etc. So anyways originally I was just going to get a full B16A swap with engine and tranny included and just swap it in but two of my friends are suggesting doing a B20B with a new B16 tranny because its about 600 bucks cheaper and it would be faster in the city then the B16 with B16 tranny they said.
So I’m pretty much decided on going that route, I can get a JDM B20B for $390 CDN with a 3 month warranty and I can also get a B16 tranny from the same place with a 3 month warranty for $650. So total $1040.
From the same place I can get a full 2nd gen B16A swap for $1500 CDN.
The place I’m getting these parts from is the most respected place in my area and everything comes with 3 month warranty so its my best option as far as where to buy from…
I’m interested in hearing what you guys have to say and also if I decide to go the B16A route I know it would be a straight swap with what I have there right now which is easy as pie. If I do the B20B route I need to know of anything I have to watch out for, little tips and tricks from the guys that have done it before basically. Like I can use the engine mounts I have on the car right now correct? My buddy said use a PR4 ECU for the B20B with B16 tranny route that sound correct?
Also I thought about doing a B20B-VTEC build because the head on my B16A is still fine. So if I were to do a light B20B-VTEC build what would be required for that?
Basically I have $1800-2000 CDN to spend on this, and I would definitely like to do the B20B-VTEC build before I put it in but if its going to cost too much then it will have to wait.
EDIT: The B20B I’m planning on using is this one.
http://www.jdmtigerjapanese.com/product_info.php?cPath=23&products_id=66
