Did your guys Drag downpipe clear the crossmember? I am having problems getting mine to fit.Uggg This ain’t no damn Bolt-on KIT!!!
thats cool sounds liek a pretty good deal… i saw your #s in your thread and they looked really good.
Thanks…Well…My 3" Down pipe is soooo close to the Crossmember that I was thinking I should cut it a bit…Luckilly the A/C compressor fit…Just had to remove it…Bolt on the Down pipe…Re install the Compressor and remove one of the heat shield bolts…I am just having an issue with the Turbo Oil Return line…The Shop peeps made the Return line hole on the Oil Pan (I think) a bit to low…And the hose is fat and it almost touches the freekin DownPipe…What did you guys do with the Return line…?
Oh and my Oil Sending unit T broke 2 times already…Hopefully this time it will hold…
How did you guys get your 2 1/2 drag downpipe fit? I am having a problem with mine to fit without touching the crossmember.
Hmmmm…I’ll take a picture of mine today…You will have to cut the cross member just a bit there then…Don’t know if it is a safe Idea…But I will be doing the same soon aswell…Hopefully soon I will be getting my Open Wastegate Tube welded to the downpipe…Less Exhaust Leak Noise…LOL
I finally got the bad boy started. I’m excited. I Just took her around the block just to make sure things are in order. No leaks as of yet. I will finish up all the little things when I have time. Here she is as she sits. The sound of the Turbo spool is awsome and open downpipe is annoying! heh
thats solid man. Keep the pics commin :cloud9:
