I finally decided to make a thread to introduce/show the work I’ve done to my 91 integra. Some friends have been bugging me for years to make a build thread but I never had time. I will give a quick introduction of how the build started and update with pictures as how it sits at the moment. This will not be updated on a daily basics like other builds because I don’t do much to the car anymore. (for now)
note: All of the work has been done by me and my father at our shop.
Block
92 b18a1
p30 oem pistons 81mm
ARP rod bolts on stock rods
ACL race bearing, main, washers.
itr/gsr oil pump
gsr water pump
gates racing timing belt
HEAD
b16 stock head
b16 sir II cams
p30 intake manifold bored out to 70mm
BBK 70mm throttle body
AEM cam gears
AEM fuel rail
stock 240cc injectors
blox fuel pressure regulator
ARC super induction box/intake
Exhaust
AN-R race header
RS*R catback exhaust with oem dual tips
ECU
p28 with a skunk2 base chip.
Transmission
93 ys1 case
99 s80/gsr hydro internal with b16 4.4 final drive.
Suspension:
Full ES master kit bushing.
D2 coilovers
Eibach front strut bar
Blox traction bar modified to work on 2gen integras.
Datum rear sub frame brace modified to work on 2gen integras
jdm itr 23mm sway bar
Skunk2 rear lower control arms
Interior
old 18yr+ carbon faux steering wheel.
93 complete change over. seats, carpet, headliner, door panel, trunk carpet, and rocket panels. (the car was tan interior before)
k-tune shifter
92-93 oem armrest with working cupholder
gsr shifter custom painted
autometer gauges. boost/vacuum, airfuel ration. volts, oil pressure.
custom LED shift light integrated on to the cluster
B and C pillar bars
Canadian manual seat belt conversion.
Exterior
Full 93 spec change over. front and rear bumpers,smoked taillights, wing.
jdm one piece lights
type r style lip.
smoke amber bumper lights.
Bought the car in February 2009 completely stock with everything oem including the 18+ year paint/dings/scratches that came with the car. the car had a burned clutch and I had to tow it to my shop.
The next day I replaced the clutch and installed my brand new one piece headlights I had bought years back when I didn’t even own an integra. Also put on my mugen mr5 on the car.
This is when I was building my LSVtec and had the parts in my room.
Motor was done. (will update with more pictures on the engine build.)
Drove the car for a few weeks and decided to start on my full wire tuck. Started with the passenger side, driver, and finish with the center firewall hole.
note: by this time I was already working on the engine harness with the new motor that was going to be dropped on the engine bay.
Took me 3 days to finish the wire tuck and I started to prep the engine bay for paint. (don’t have pictures right now but will update later)
Every single bolt, nut, rack, sub frame came out to be able to paint the engine bay properly. (I’m a very picky person.) lol
