I’m looking for a Moroso style oil pan but everyting I’ve found is for 94+ tegs. Is there a difference in the mounting and gasket between the 94+ and gen 2’s? If so, does anyone know where I can get a specific pan for my bottom end?
~Keith
~Keith
any pan for a B18a/b or B20 should bolt up to any LS motor.
The difference is the pick-up. The b18b uses a diffent style brace than the “A”. I had it on mine and it is easy to midify, when you go to bolt it on, you will see a little tab that needs to be trimmed. But it will work and the pan bolts right on.
Nice… good news. I hadn’t picked this up yet so now that it’s confirmed I will for sure… quickda6, you’re 0 for 2 with me homie… I’ll hit you up if I’ve got any other ques… thanks!
~Keith
That would be you’re “2 for 2 with me, homie…”
smackinface How sillie of me…
