has any 1 have or tried the garret 3076r
never had it but its a great turbo
Yep. I ran this turbo with the .63 hot side on my 2L GSR motor boosting 30psi. what do you need to know.
how much power did you get from it. if i boost my 2.0L gsr im going gt42r… :ohyeah: i might just run a whole bunch of nitrous and let it be with ported oem header. ahaha.
i just want to know if it spool fast and is it a good turbo in general .Because it cost me 600 more to get this turbo thx
I feel your pain, but not really.
600 is a SMOKIN deal on taht turbo if it is the real deal and brand new.
As for how much power it made. with the smaller .63 at 30psi It was an estimated 500whp gonig by trap speeds. Could be less. it was on a very conservative tune. On my car, the spool tiem isn’t that bad at all. full boost around 4800 depedning what gear. at 30psi that was mroe like 5000. But I’m also shifting over 9 grand. But overall it’s a perfect tyrbo IMO for daily driver but also big power.
3076r would be ball bearing right? maybe it is just a 3076, non-ball bearing.
thx tchleung my is a 3076r with 1.6a/r .im hoping to make about 600 whp with my build bottom and the head work i have done:ohyeah:
1.06a/r turbine?? That’s pretty big. IMO if you’re going such a large GT30R, I would go for a smalelr .63 turbine GT35R. you’ll get the same spool results as the big 1.06 GT30R if not better, and you’ll get more top end.
thx again tch but is installed already ill keep u posted wat i make
