Anyone heard of inline pro
Has anyone ever gone to www.inlinepro.com or used there parts. Im looking into getting there 2mm head gasket, just curious if anyone has tried it on a stock b18a with basic fuel components and injectors. How much boost did you run or can i run safely. A friend called and they said up to 16 safely on a d16y8 i havent had the chance to call them about a b18 though.
supposedly most of those cars have stock internals and stock ecu. only thicker head gasket and more fuel. :rockon: oh and more BOOST :burnout:
I’ve been there. That is the manifold I planned on gettin if I go turbo. I think you would have to get bigger injectors.
im getting dsm injectors 440 or 450s i think but from what i hear with that head gasket you need cam gears to retard the timing but you should be able to run 16-18psi on mostly stock parts
2MM is alot tho. that will throw your timnig off a decent amount. It retards you a tad…or was it advance…
it will advance your timing thats why you need adjustable cam gears to retard it :smiley:
Motors like detonation :clap:
When I ran 300+whp on my B18A I used stock, now I am making much more than that and I still use stock hg with my B16A and my LS/VTEC. Get a good standalone ecu that has some sort of boost retard per pound of boost with some good tunning and you would be surprised at how much boost a stock motor can take. But if you run the boost, use ARP head studs, I swear by them and would not boost any motor without it. Tell your buddy to cool on the boost on that D series tho, have you seen the thickness and size of their rods :shock: that is the weakest link on that motor.
Would you be willing to e-mail me what your set up was including everything to the head studs, also what about rod bolts?? e-mail me at Superfly_125@hotmail.com
do a search under my User name and you will see all the parts i used.
