Anyone run this setup or something similar?
Alright here’s the deal i have a 92 teg and a spare 89 b18 im freshining up with new rings, seals, bearings, gaskets, block gaurd, and Arp rod bolts and head studs.
my question on that is will i have to change anything on the 89 engine to drop it into my 92?
my turbo setup will be a
14B turbo
DSM 450 injectors
custom exhaust manifold
custom downpipe - will 2 1/2" be enough or should i go 3"?
again is 2 1/2" or should i get 3" on the catback
FMIC i got from homemadeturbo.com
custom press bent pipes with a Greddy type-s bov
walbo 255lph fuel pump
Uberdata - i’ve heard a lot of good things, is anyone here running it?
gauges- boost, oil pressure, A/F, and water temp
ACT 2100 lb clutch
oil lines and fittings
will i need a FPR? or can i go without one
hallman MBC
i plan on running about 7-10 psi
thats about it, has anyone ran this? I need some quick responses im in the process of the overhaul right now so lemme know.
thanks
it will bolt right in
:clap: Uberdata
do i have to do anything with the harness? can i use the one out of the 92?
your 92 teggy is already OBD1 so you are good to go
The 92 harness will work on an 89??? Aren’t they both completely different obd? I would think you could swap everything over from the 92 motor to the 89 but not completely sure?
all of the sensors should be the same…if they arent swap them over yes
Also, another thing, weren’t the older integras dual point injection instead of multipoint? Not sure here…
no B18a motor was DPFI…they were all MPFI
I know that no B18a1 was dual, but I thought the 86-89 was the D16a1 Dohc 1.6ltr? Or something like that?
yes an 86-89 integra. didnt they come with D series 1.6
Yes. they came with the 1.6L D series DOHC. I forget the exact engien code. SOmething liek D16A1 or whatever.
ZC engine fellas…
Too bad the USDM 1st Gen tegs didn’t come with the real JDM ZC :frowning:
yeah… so what i have is a b18a1 no zc here, alright back to the subject anyone ever run something like that or no? :hmm:
Yeah, that’s what I’m saying. You said you have a spare 89 motor that you’re freshening up. I didn’t know that the 89 model came with the b18a1.
