i’m about to install my moroso catch can. the stock breather box is sealed with the z10 plug. i’m useing the 2 ports on the back of the block to the catch can. the fitting on the valve cover also goes to the can. i also welded 1 -12an line on the front of the valve cover that also goes to the can.
i was just wondering it there will be any problems since this is a open system and there is no vacuum on the motor. will this cause any problems
should i run the pvc on top of the can and run a lineto the intake preturbo for vacuum to make it a closed system insteam of running the filter on top of the can???
please help!!! i’m just worryed because i heard that this is not good because there is no vacuum on the motor and i heard vacuum is needed to properly vent the crancase pressure
