My friend is selling me a B18c V-Tec Head with about $600 work or more into it on a B20 Block. I am in need of a head job on my LS so I was just thinking of coming back V-Tec Style. LS-V on boost.
If I could find a nice low milage GS-R motor then that would be the route I would take. But that will cost me like $1500 more.
What do you all think?
My LS needs Head work but all is fine with it. I can put the B18c Head on my LS bottom if anything…Along with my 92 GS-R Tranny.
Thanks for the info…But this will be a B20 Bottom and a B18c VTec Head…Will that work?
yes that will work just fine, it’s called either crvtec or b20vtec, you’ll need to get some gsr parts like a timing belt, water pump, oil pump, etc…and you’ll need to tap the head for an oil line just like lsvtec.
it’s a great combo, real torquey and the C/R isn’t too high for boost.
eh he should be fine for at least 8 lbs…that’s what my friends been running for over a year, and the other guy above said his buddies’ is running great on 9 lbs for 5 months, but yeah, if you want to spend $1200, get it sleeved.
That sounds awsome…I am going to go with the idea then. I guess I really can’t go wrong with it. it is from a family member and he states that it is worked up and he can get me any parts i need for cheep. He also states that the block has a BlockGuard also.
word redline no time no speak…i got me a b20vtec lol im bout to boost the bitch til i go k series…b20vtec is def fun im anxious to see what it can do on 15 psi :rockon: hit me up bro when are you coming down!
Good Luck.
Don’t you tap the Block for the oil line for vtec?
