b20 question...
I apologize for the newbness of this question in advance. Anywho, my friend has a b20 in his eg. He went b20vtec n threw a gsr head on. Then he asked me if I wanted his b20z head in exchange for my steelies that were lyn around. So I said sure. So the question is…would this work let alone fit on my ls block. If not I was just going to get a b20 block. Head came complete…
-all sensors
-intake and exhaust mani
-tb
-distributor
-cap
-everything
So what should I do…thanx guys.
Off topic…thanx to g2ic…I was able to rewire my fogs…shit looks sik.
Which b20 head is it? whats the casting number? if its a p8r then grab it
All I know is that its a b20z head off of a 2000 crv. We did the trade last night. Low miles too?. Can I do anything with it?. What a trade the. That head for 4 steelies. =)
it matters if its a p8r if its not its the same as the ls head
http://www.honda-tech.com/showthread.php?t=1466416
I called my boy. It is the p8r. So can I use it. Or do I hafto get a block?
I thought b20z’s came with p75’s? I was under the impression that JDM b20b’s were p8r.
My b20z came with a p75.
Both p8r and p75 will work and will certainly be an improvement over your b18a head
Or iono…he said he had b20z block with that p84 head. He went with a gsr head so he gave me this one. Its sitting in my garage
Ok so I called him back to make sure. Its the b20Z head. So can I use it on my ls block or am I better off getting a b20 block
if its not a p8r head its the same as the b18b/a head it flows like shit you wont gain anything from it u will loss C/R anyway
What if it was that head. Will it have workt and would I have gained anything?
P8R heads flow like vtec heads.
all he has to do is check the stamp right? and it should have the p8r or p75 correct? if so then do that man itll take longer for u to walk over there than it will to find out which one it is
^^ correct
slowly gaining the strength to remove the noob name tag off my chest…lol
Dam its the p75
deng sux… wish u had those steelies back now dont u… and how good of friends are u with this guy cuz unless he didnt know wut he was talking bout then it sounds like u just got bamboozled
Sale The Parts You’ll Make Some Cash
b18a’s DID NOT come with p75 heads. The b18a used the pr4 head.
b18b, b20z, and USDM b20b used p75.
JDM b20b and b20b4 used both p75 and p8r. p8r was WAAAAY more rare.
Dam…well…I do have another set of steelies. The set I gave him,2 of them were bent.hah…oops…so should I juss sell the head? Or get a b20 block so I can use it? So do I basically have a head I can’t use or gain from on my car?
i guessed u gaffled eachother then… haha
