base line safc2 settings
im looking base line safc2 settings for my friends teg with dsm 450cc injectors and a nice little t3 i gave him…
any help would be greatly apriciated
I dont know much about the safc2 …
I use the stand alone Megasquirt’n’Spark on my turbo ford escort
run -35% correction on every setting then drive to a shop withotu revin high or hitting boost and get her tuned. if you don’t have a wideband yourself.
we have a lm1 :slight_smile:
thnx thatll help a lot
Yep. chances aere you’ll probably be working in the area of -40% as -35% rusn you pretty rich. but it varries on each setup.
ive heard u have to run the 3bar map sensor over 10 psi??
yes you need to upgrade to a diff resolution map sensor to bosot past 10psi
