base map
ok does anybody know how to map a base map or know where i can get one,i have a b18b t3/t4 turbo,2 1/2in dp and icp,550cc inj,fuel pressure reg fuel rail,and more,let me know ASAP PLEASE i need help
thanks mike
http://www.xenocron.com/bins
yea i found that one but i only found one for 450cc inj and i need 550cc inj
Is it just to get you from point A to point B to get it tuned, or are you looking for a map to run for awhile? If it just needs to get you to a tuner, that map will be fine for you. It will idle crappy and run a bit rich, but should be fine to get you where you need to go as long as you take it easy like you should.
use Xenocron’s basemap helper…
