[QUOTE=91akira;2028034]I have the same issue but I found where the circuit is drawing power in my car. I disconnected that source and got the same test reading of .04 which is good. Car started even if car sits for a week. I had a 0.39 draw before.
I’m confused why your still drawing power even with a 0.04 reading and that you changed your battery.
By the way, what exactly did you do to the 70a main fuse? How did you find out that was bad? Was it corroded or just lose? Did you replace it with a brand new one?[/QUOTE]
Below is my only reason to know the drawing even just with 0.04A…
![](http://i135.photobucket.com/albums/q123/blabong33/DSCF2189.jpg)
Another testing,
Early morning 10am i check the voltage is 12.48V,
Then i check again the voltage on night time 10pm,
Result is 12.23V…
Then i leave it untill the next morning 10am and check again the voltage,
Just have 11.89V only…
Still leave it,
Final check on 10pm,
Just left 11.43V only,
Then i need to on my engine to charge back the voltage…
Normally when i on my engine every morning with the voltage above 12V,
The engine crank sound just “ZE ZE ZE ZE ZE”,
Then my engine can start already…
After the 1st time on,
Even i drive the car go to shopping or go to work and parking a whole day,
When i start again the car,
Just “ZE ZE ZE”,
Then should be on already…
But,
If i just leave the car whole day and din’t start it,
The second day morning time also just leave it,
Untill the second day night time just try to start the car,
I need to crank more longer,
“ZE ZE ZE ZE ZE ZE ZE”,
“ZE ZE ZE ZE ZE”,
Then the engine can be start…
If let say i leave my car more than 2 day,
And i crank on 3rd day morning,
NO SOUND at all…
I need to crank and re crank untill the crank sound or starter sound come out,
Then i just have chance to ON the engine…
Some more,
Even i successful on the engine,
But the engine similiar like no fuel can go through the engine…
Example:Normally when we crank the key with the sound “ZE ZE ZE”,
The RPM will direct rev to around 2K and engine started…
RIGHT???
But,
When i successful start my engine,
The RPM will stun a while,
Then RPM rev to around 2K and engine started,
This case happen when i din’t start my car more than 1 day…
Normally people will suspert my fuel pump problem…
But,
If i take out the battery cable connection,
Even i park my car more than 1 week,
I aslo can on my engine with nothing problem…
Just need to crank longer a bit only(“ZE ZE ZE ZE ZE ZE ZE ZE ZE ZE”),
RPM also can directly rev to 2K and engine started(NO STUN)…
All is my experience…
Then,
About 70A main fuse loose contact…
I ask a favor form workshop technical to help me clean all the dirt on engine bay,
After the cleaning and rinse with water and blow to dry,
I park my car and continue chating with workshop technical…
When i plan to leave that time,
I cant start my engine,
Alarm system also shut down…
Then i find out is 70A main fuse wire already split to two,
Not corroded…
So i just change a new main fuse and check again the drawing,
So suprise because the reading drop to 0.04A,
But the problem still remain…
PS:My language not very well,hope you’s guy can understand it…
