Ok I will start from the beginning.
About 2 weeks ago I pressure washed the block. Nothing out of the ordinary, covered all electrics and even stayed away from them. The main reson was i had blown a coolant hose a few days prior and wanted to get that all off as well as get old oil from an old leak off.
When we tried to start the car…it just cranked. this is after drying everything off with 120psi of air…i mean not a drop of water was left.
I kept getting this smell and this weird backfire outta the intake manifold. After waiting the car started right up and ran fine. As as the days went by the car got harder and harder to start, it would just crank…did my research and it turned out that the timing belt was loose. It only had about 7k miles on it, but I guess when I took the car to 2NR Werx (in Tampa)they never replaced teh tensioner.
We replaced the timing belt and tentioner and got the CAM timing dead nuts on, and the car started right up! The ignition timing MUST be completey advanced for it to run (ODD) and it feels like it has lost some power and “boggs” under a load (high rpm is fine) and wants to shut off from any abrupt start. I have to ease into a start and accelerate easy. Other than that the car runs fine, idles normal, no coolant loss, no missing anything
Compression is @ 178 on each cylinder, Spec requires 200 on a brand new motor and it has like 191,8XX on a B18A1 all stock internals with bolt ons. I guess that means that the headgasket and valves are ok…NO SMOKE EVER!!!
Fuel pressure is a steady 139psi, Spark is PHENOMENAL all the way from the box to the end of the plug (full MSD setup)…6AL box, Blaster SS coil, Power Cap and rotor, wires are good and NGK iridium plugs gapped @ .45. Even got new reg plugs and didnt help
Cleaned out the breather box and replaced all corroted hoses and PCV valve and there are no vacuum leaks AT ALL!!
HERE IS THE PROB NOW:
Yesterday, while on my way to my buddies house, it was “bogging” like crazy, and when I stopped at the store it took 4ever to start. I get it to my buddies house and checked it all out and noticed that the belt jumped again?? It no longer is lined up with the white line on the crank pully, its on the 1 of the 3 lines just before it. Cams are lined straight up when at TDC and the Distributor is line all good too.
I have had so many people try to help and work on it for hours and we dont know whats wrong…
I NEED HELP!!!
