big 16g
i have the big 16g turbo and i was wondering if anyone here has used this turbo on a stock setup? if i was to run this turbo on a stock setup, what kind of power would i be making? i got it for a deal i couldnt pass up and i dont really have much info on it. i was told that it is internally gated to run at 12 psi.
Please post a pic so I can tell you what you have?
it’s good for up to 350hp. If you plan on using it for drag I would look else where. its more of a autox/street set up.
[SIZE=“2”]yeah, thatblkguy is right. Its a good turbo, spools almost instantly and gives BIG power & torque from the beginning and mid range, but it eventually starts running out of breath around 5.4k rpms. Its a Mitsubishi turbo and my friend had one on his car.[/SIZE]
