Black as night. 91 DA project
That’s what I meant, obd1.
write up
No pics but tells you everything.
Well I hit a bump that i hit everyday(unavoidable) and it caused one of my exhaust hangers to break… Lucky for me Oviedo is a small town where im either down the street from my house or down the street from the shop. and i still havent done my rear brakes, and its metal to metal. :frowning:
Been busy a while, but I got some work done today. Did a valve adjustment and a compression test today. Results:
Cylinder 1-200 psi
Cylinder 2-180 psi
Cylinder 3-180 psi
Cylinder 4-185 psi
All within 10% :rockon:
I need plug wires though
nice numbers:up:
Thanks man. :up:
well, last night I finally replaced my drivers side lower ball joint because it was squeeking real bad. It took some ridiculous amounts of beating a ball joint separator (pickle fork) with a sledge at 10pm. Needless to say my neighbors hate my guts real bad. I’m gonna do the other side later today.
Car is driving great. No more squeaky balljoints. :up:
This weekend I decided I was gonna calculate my gas mileage, so I filled up my car and drove 112.7 miles in 2 days. This morning I topped it off with 3 gallons which means…
Approx. 37.5mpg all City. :rockon:
Next time I go to Miami I’ll measure my highway mileage.
After that I plan on getting a Tanabe exhaust or a custom Magnaflow.
Trying to help a fellow DA/DB owner out with a compression test?
The compression tester belongs to my school. And the only way to use it is to have the car at school and I don’t have time till next week, I need to see a cardiologist tomorrow…
It’s all good. I forgot mine back in VA when I moved down here and was just giving it a shot. At least you didn’t say fuck off like the last guy lol
Its cool. I don’t mind helping people out because i hate when people are douche bags like that.
Just bought a new battery for my car because it wouldnt start this morning and it made me miss my class. O well, New battery and the teg is running smoother with it.:dance:
Just so you know…there is a group of us who hang out pretty regularly here in Casselberry, by Red Bug Lake Rd! We need to get together sometime. I have a few 2nd Gens and usuall have a slew of them here on a regluar basis.
[QUOTE=lawngnomeslayer;2209586]Been busy a while, but I got some work done today. Did a valve adjustment and a compression test today. Results:
Cylinder 1-200 psi
Cylinder 2-180 psi
Cylinder 3-180 psi
Cylinder 4-185 psi
I need plug wires though[/QUOTE]
In my compression test kit i have a paper that came with it and it says if our cars are below 183 its not good, says rebuild will need to happen asap,
G[QUOTE=DAG;2215268]In my compression test kit i have a paper that came with it and it says if our cars are below 183 its not good, says rebuild will need to happen asap,[/QUOTE]
Thats incorrect information, ls motors are low compression and his number are right on the money.
On a b18a1 engine the compression results should be btwn 135 minimum to about 199 depending on if its obd0 or obd1. There should never be a variation of more than 28psi per cylinder.
You would have had to buy a compression test kit specifically for a b18a1 motor for that manual to he correct…you shouldnt post information that you are un sure of…can cause more harm then good.
Havent updated anything in a while. Work has been owning me, 6+ days a week at the inlaws bodyshop.
Last month a rust patch on my exhaust broke and dropped the rear half of my exhaust. I got unbelievably loud and sounded like some of the douche bags driving civics with straight pipe… I couldnt hear myself think for a whole week, then i finally got around to welding the break and patching all the holes. sounds beautiful now. :up:
Last week i took an hour drive to a transmision shop to get my girls transmision done. On the way back my radiator thought that the halfway point was perfect for blowing a hole between the core and tank. I did manage to patch it and get home. Now Im the proud owner of a mishimoto radiator and new oem water pump. I never thought a radiator could look so beautiful. :drool:
Hey da92nv: You still meeting in casselberry? Hit me up with some info if you are: jumpmaxx@aol.com
