Bogging probems!!!!
Yo whats up guys… I have a probem. My car, since the first day I got my turbo kit, bogs when I step on the gas all the way to the floor. At first, I thought it was just that the turbo had to build boost, but i was talking to the guy who sold me the kit, and his internally stock car didn’t do that!!My wastegate’s set at 7, but it boostes around 6. My setup is as follows:
Turbonetics T3
Deltagate Wastegate
Greddy type s BOV
Vortech FMU
Stock injectors
Holley external fuel pump
MSD 6A Ignition
Dynomax cat back with high flow cat
Spearco intercooler
everything else is stock
Any help is appreciated…
Alex
oh yeah, I also use check valves so my CEL wont turn on. My car runs lean under boost, according to my a/f gauge. Also, when I pulled out my plugs, the porcelain pieces on 2 were broken! The plugs were cold denso iridium gsr pugs. The plug tip looked alright though… Anyways, HELP!!!
Alex
Damn, it just occured to me that I dont have my O2 sensor connected… Can that be the reason? I have my a/f connected straight to the o2… but the o2 harness is untouched. The guy who installed my kit said it would run better without it…
ALEX
SOMEBODY HELP!!!
The bogging is because you have a cat. The broken insulator is because you run lean and detonate, connect the O2 sensor…fix the running lean problem
