where through the firewall are you guys runing the pressure line for the boost gauge? thanks alot! pics would be awesome!
I have a 7/8" hole for clutch cable, wiring, boost gauge, etc. :shrug:
there a gromet that is blank
i used for my amp/2step/and now boost
where is it on the firewall?
near/under the throttle cable
im gonna be doing mine in the next few days ill take pics and post for you
i was able to find it thanks! but pics would be great expecially for future refrence
use the same hole ur clutch cable goes through and use ur fpr’s line
i actually found an open hole with nothing in it? i dont know if evey teg has it or if its just the way this one was optioned.
i found a really nice hole in my firewall which i fed vacuum line for boost guage and wires for my aem wideband guage, its located just about behind the alternator and it comes out behind the brake pedal about 6 inches above where the actual pedal rubber part is where ur foot actually hits the pedal…decent size hole, I have room to fit a few other things thru it also if need be, hope this helps bye
If you have cruise control and don’t ever use it, you could take it off. The control cable runs through the firewall and would be big enough for 10 boost gauge lines.
