Looking to boost my car within the next month or 2 just wanted to know if there is anything i should do before i boost besides compression check right now i have a rebuilt b17a bored .25mm over with p&p type r head mods unknow to head,but i know the guy upgraded the cams or somthing, lightweight crank pulley, .25mm over gsr p61 pistons i know i wont need cai so i wont add that and also 2.5 inch exhaust. Right now im sitting close to 200whp so if i boost im hoping to reach 300whp or more any suggestions welcome thanks
it may be ideal to figure out what cams you have if they have been upgraded
not sure if they were or not but ill check
Btw it only has about 10k on the motor since rebuild
You have too many what ifs… Find out what you have and then proceed. Chances of you having a high lift cam is going to be very high if your already at ~200FWHP… FYI…
