boosting B18A1... Ignition?
Im building and boosting my b18a1 with a 350+ hp goal and was wondering what I should do ignition wise. Can I use my stock dist. or should I upgrade? Also what about the coil and control module?
for the most part, the honda stock ignition system is reliable for street power near the 400 mark. it may not give an accurate signal for the horrible indash tach, but it does work well.
i would suggest that you use the stock system till you hit its limitation during the tune. try everything you can think of to adjust on it prior to pulling it. the reason i say this, is because some stock systems work better then others. but i do know that aftermarket ignition systems rarely work well in a honda chassis.
edit: you could also look in this thread (click) for set-ups near your power goal and take note of thier ignition systems.
B18A1 Turbo 350hp
Ayone else have suggestions on an ignition set up for my build goal??
stock is more then fine for your power goal.
Seconded
