Boosting Engine
My engine is a B18A1, with 300,xxxKM, did a compression test (170,175,175,181) Looks to be in very good shape. No leaks either.
And I was wondering what are some things i should do to it inorder for it to handle about 12psi max?
With the best tune ever, nothing. For a DD, keep the psi a bit lower maybe. What turbo are you planning on running?
If you plan on going big, might as well get forged internals and a rebuild.
bump
Ok, heres the plan.
My engine is a B18A1, with 315,xxxKM, did a compression test (170,175,175,181) Looks to be in very good shape. No leaks and burns no oil.
I am getting a T3/t04 turbo, 450cc injectors, 255lph fuel pump, and a chipped OBD0 ECU. I plan on running about 8psi for street and a max of 12psi at the track. I was just wondering do you think my engine will be able to handle that kind of boost(s)? If not what are some things that I should change/replace?
It can definetly handle that with a GOOD TUNE.
Alright thank you.
Stock ls motors are good up to 310 hp. Thats with a good tuner like st00pid.
friend of mine( boostedteggy texasracingscene.com) dynoed at 303 7 months ago and is running mid 12’s
Thanks for the heads up, its very much appreciated. Please keep the inof coming.
