im in the process of fabrication the ic piping, but i need help to where you guys relocate the winshield washer fluid bottle and coolant reservoir?
also what if you retain the power steering system, do you move the reservoir for the power steering also?
thanks
i removed my windshiel washer fluid. and as for the PS, I just removed the cooling lines in side the bumper.
take that shit out, what do u think gas stations are for?
i took the washers out from when i put on the cf hood, you just need to relocate the hoses and pump probably. my ps didn’t need to move and i put the overflow on my crossmember.
same as loserpunk
never used it since cf hood
but my overflow is in the stock palce
system
June 19, 2006, 8:19am
6
Sorry if this sounds stupid but what is the overflow you are talking about?
system
June 19, 2006, 7:25pm
7
Radiator overflow bottle.
i got the ic piping to fit tightly with everything in place including power steering.
I just want to know if its bad that the piping is touching the hoses.?
nope, i had my rad and ps resivoirs in
