bov chattering
when i let off the gas while in boost how is the bov supposed to sound? a chattering noise? there is a right way it should be expelling the air correct? do i make it softer or harder to make the chattering go away?
what kind of BOV. If you have it too soft it will chatter. Where is the BOV located in comparison with the turbo and intercooler. If you just slapped on the bov it probably needs to be tightened. How much boost are you running?
type-rs, it is located to the left of the battery box area. meaning after turbo and after intercooler before tb. 7lbs. i dont want to run my car around yet since its not tuned, it just has a basemap so i adjusted it twice and ran it twice so far and have been tightening it since. but I still dont wanna mess anything up on an un-tuned engine. thanks for the help!
so did that work?
sounds like it isnt blowing off and u are actually hearing compressor surge
