Hi,I need some advice or pics to see how & where to brace turbo…there seems to be no place to brace the turbo…i look all over the block i can’t see a good spot on the block to do this…advise would be appreciated. :bang:
thanks
thanks
I just brace the DP, before the flex pipe.
It’s not clear what you mean by ‘brace the turbo’ but if you mean finding a way to support its weight other than the manifold studs then your best bet would be to fabricate a bracket and bolt it up to the power steering or AC mount holes.
that is exactly what i was asking…support other than the manifold studs.
thanks
use your head…there are plenty of places to brace the turbo at. custom make a bracket to bolt up to the center section of the turbo.
