[QUOTE=Ominous G2;2167533]Looking good, I hope to be doing this also. Just trying to figure out how hard it will be with the engine in. :argh: Thanks for the degrees on the banjos, I was trying to figure out what I needed to get them to look like that.[/QUOTE] you might want to take the intake manifold off for more room…but i have collected all the parts that you will need to not includeing the 37 degree flaring too that you should not be skimpy on buying…(rigid tool) is the one i got and love it!!! i am doing a brake line tuck in a crx tomarrow with a kswap so i will take some pictures and let you know how it goes
this is all from summit racing:
everything you need… cost of parts: $230 thats with shipping
about 20 feet of 3/16 brake line
Fittings, Bulkhead Nut, -3 AN, Steel, Zinc Plated, Pair
Part Number: EAR-502403ERL qty (1)
Fitting, Tube Nut, -3 AN, Steel, Zinc Plated, Pair
Part Number: EAR-561803ERL qty (11)
Fitting, Tube Sleeve, -3 AN, Steel, Zinc Plated, Pair
Part Number: EAR-561903ERL qty (11)
Fittings, Brake, Male -3 AN to Male 10mm x 1.0 Thread, Steel, Zinc Plated, Pair
Part Number: EAR-592032ERL qty (5)
Fitting, Adapter, Banjo Bolt with Crush Washer, 10mm x 1.0 Single, Steel, Zinc Plated, Each
Part Number: EAR-997517ERL qty (2)
Fitting, Coupler, Straight, -3 AN Male to -3 AN Male, Steel, Zinc Plated, Each
Part Number: FRA-581503 qty (2)
Fitting, Straight, Bulkhead Union, -3 AN, Steel, Zinc Plated, Each
Part Number: FRA-583203 qty (2)
Fitting, Brake Adapter, -3 AN to Straight 10mm Banjo, Steel, Endura, Each
Part Number: RUS-640471 qty (1)
Fittings, Brake Adapter, Steel, Nickel Plated, -3 AN to 35 Degree 10mm Banjo, Each
Part Number: RUS-640511 qty (1)
