build setup Q's
ok so i gotta b18b1.
the oil ring on the number one cylinder is broke i think…
compression test revealed that number one cylinder was lower than the rest.
or it could be a valve seal guide… I dont know.
BUt…
i bought new rings
new headgasket
acl rod bearings
acl main bearings
and i really want to go boost and i have some money now so.
my question is.
should i save up the money…
and buy some arp rod bolts and head studs…
or will stock ones be ok???
i want reliability but want boost too what should i do???
and please explain to me what the machine shop has to do to put in arp rod bolts…
maybe even pics…
thanks a lot
iKnow this has been covered a thousand times but i dont understand what they do to the rods…
http://www.g2ic.com/forums/announcement.php?f=18&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
