building my motor need rod advice
got a 92 integra block im building, want to make sure that these are ok… i plan on getting Manley h beams,(guy said they will handle up to 600 hp… heres the specs…
Center-to-Center 5.394", Big End Bore 1.890, Big End Width .935", Pin Diameter 827" 21mm ,Pin Bore .8281,Gram Weight 520… let me know i have a t3/t4 turbo 57 trim turbo want to be able to push 12 -20 psi here and there… the guy i have doing my motor work brothers in the hospital and i just want to make sure these will be fine to buy, also plan to use je pistons… thank you for taking the time to read my post.
anyone???
I havent heard much about these, but if your looking for something strong and you havent got those manley’s yet, they make a turbo tuff that I was reading about that is really good, and of course you can always get pauter too. it’s hard to say if that rod is good just by the dimensions. all rods for a LS should be close to those dimensions.
ok thank you just hoping the are stronger the the golden eagle ones. and the pauters are expensive… i just want something to handle 400 hp or lil better,without killing my budget to much since imworking on a rwd car as my main project rite now. thank fior your information
to be honest with you, I would go with eagle with the 3/8" ARP bolts. you should be fine for the power you are trying to go with and they won’t eat at your budget much, but if you want something gangsta:gunright: , then go Pauter!!!
eagle rods will hold the power ur trying to make. i’ve seen them hold 730hp no problem
eagles for sure, if you need em cheap i can hook you up with a link for them for 295 shipped
hook me up with the link plz!! also have you dealt with this company?
make sure they are the 3/8" size bolts. I had the 5/16" bolts on my old ones.
i actualy cant find the link right now, but i still have there number, i found another company but cant vouche for there service
the one i have the number for i’ve personally bought from when i was building my Z6, had my rods in 3days
hit me up on aim if you have it and i’ll give it to you
Aim: WolfGod599
If not there, then I would hit this guy up here. he’s been selling on there for over a year. pretty good service… his prices are great!!!
unless you plan on reving to the area of 9500+ on a consistent basis, making over 700 at the wheels, there’s no reason not to go with eagles.
Golden Eagle doesn’t make rods. Eagle is the name of the company, and there’s no affiliation with Golden Eagle MFG.
^^ thanks i didnt know that figured it was the same company… yea im going to go with eagle rods thanks…
