car hard to start
sup peoples…need a lil help…latey my car has been a bitch to get started…
i changed plugs, wires,cap and rotor…
it’s takes about 5-7 mins to get it started when it’s cold…when it’s warm it runs fine…
the motor crank, turns over then dies…after a while it starts and everything is cool…yes the cel light is on but i was assuming it was an emissions code (no cat)…my only guess is it fuel related…if so what is it and can a normal mechanic repair…my turbo mechanic is about 40 min away (thats you chris if you read this)…
i’m running dsm 450’s crome pro with a walbro pump
help me out i want this fixed asap
anybody…someb:read: :read: :read: :read: ody…
what plugs are you running? can you hear ur car prime? i’m running straight through exhaust and i have no CEL so i would jump urs and see what it is
how are you going to ask why your car doesnt start and you have a CEL. Get rid of the CEL and then see if it fires up on 1st crank.
my fans are wired constant so i think i hear it…as for why i’m asking this question…like i said mostly likely the cel light has to do with the fact that the plug from the o2 came loose…i’ll jump for the code on sunday
my guess would be the MFR, quite the common failure.
