car not building boost help....
I have a problem that im not building boost… i know it possibly could be a vacumm prob but ive gone through all my vacumm lines over and over and still 0-psi of boost when i drive… i have a 92 integra da, i have the GE vacumm manifold and have the following pluged into it… BOV- FPR-boost gauge,profec-s boost controler,3bar map sensor, i have those 5 things running off GE vacumm manifold… im running a tial 38mm and i have the side of it vacummed to the turbo… can anyone tell me anything that i need to check cause ive done everything that i could think of… when im at idle and i rev the motor i hear the bov blowing so i dont think the turbo is bad but why am i not boosting… help!!! thanks in advance…
hmm, i dont know much as i put together a pretty simple setup…although i noticed you have your wg vacuum connected to the turbo, take it off and route the wg vacuum somewhere else. i was loseing boost due to having it the way you do…hope this helps any, good luck! :slight_smile:
Carlos – whats up …? we meeting at Towers on friday night … see if u can come by… check the meetings section – . don’t know if u want Trent to look at it
sup hayden… i’ll def stop by… but the da wont be on the road yet… i gotta get it tuned again…
i know Dave moved to Naples – if u still have his # call him maybe he may be coming over soon…
ohh i see … yeah i still have his nextel wlakie… i tried him but nothing… i also tried getting ahold of trent but i dont think he has the same walkie #… can you give me trent’s # or tell him to call me … i need a little help… with some vacumm lines… 954-445-2254 thanks, hayden…
i pm’d dave on Tuner-solutions-online.com/forum
If you need a good tuner…Let me know…Frt Myers…He tuned my Teg awsome…I’ll be at Towers on Friday night…For sure…
Bro, I was just thinking, check all your I/C pipes…Maybe one is off…
