XMC coating done by fireball coating. very well done.
looks good. what is the temperature rating on these? I found that flat black or black satin to be the most assimilative
their normal ceramic coating rating is 1300f-2000f. the XMC suppose be 30% higher than that. your can check out www.fireballcoatings.com
just currius, but how much did they charge you to do all that? I plan on having Pfab ceramic coat everything between the head and the cat once everything gets welded together.
keep in mind i am in canada, it cost 425. far as i know they are the only company that have the XMC coating. usually people just wrap the down pipe cause it might get scrape if car is very low. that way if anything you just have to rewrap it which is cheaper that coating IMO.
Lookin good!
Seriously, that came out great!
