comments on future of B17Vortech
okay I can probably make at least 330 WHP with my 8psi pulley and CRV crank for a total of 11psi @ 8100. Would I be better off to upgrade my valve train and move my revlimit up to 8500 and make ~350HP :Dor:D to upgrade to the 10 psi pulley and maybe hit 350 at 8k.
The 10psi pulley route(14-16psi) will give me more power faster, I already spin tires through 1st after 5krpms and most of 2nd, 3rd hooks pretty damn well. If I don’t get into it until 2nd gear spin is greatly reduced. I might try increaseing the overall diameter of my tires. Blower efficiency isn’t a factor even at 17psi with my blower.
The 8psi pulley route (12-13 psi, higher redline=more psi) I spend more money on valve train, maybe increase power with an ITR exhaust cam. Power doesn’t come any faster just last longer and gets stronger than I currently have. It should be easier to hook with this setup. I figure belt slippage would be the same with increased rpm as it would be with a smaller pulley.
LSD= more traction
I have an LSD already qualife. Good thought though.
personally, i like a lot of low end torque, thats why i drive the car that i drive. however, in your situation, any more low end torque will just get wasted spinning tires. So in my opinion, I would upgrade your valve train to rev higher. Unless you can solve some of your traction issues, more power in the low end will be useless.
