I have an air tank that can hold 120 psi of air. Its is big enough to fillup about 1 1/2 tire. I was wondering if i could use that as a form of forced induction untill I get my turbo. I was going to make a hole in my intake tube and run a line pointing right into the throtle body and When I needed the extra boost I would just open the valve a nd let the air rush trough. I would like to know if any one ever tried that and If it would work.
no offence, but i find that to be a wierd idea. I dont think your idea would work. From how you explained it, it would be extra air being put into the system. When the air gets released from the tank, i dont think it would be compressed anymore and would just be extra air that would neglible results. That just the way i see it.
won’t work, it won’t supply nearly enough volume of air
wouldn’t be enough pressure to do anything
running pure o2 is risky and only a few have had success doing it. the nitrogen in nitrous acts as a buffer and helps the process slow down and be more reliable. in short, not a good idea, even if you do have the volume.
he said he was going to run air not pure oxygen
i was using the word “pure” loosely to show the difference between nitrous injection and “air” injection, but in G2IC fashion you got anal. ![]()
i was using the word “pure” loosely to show the difference between nitrous injection and “air” injection, but in G2IC fashion you got anal.![]()
cool, just tryin to keep things from getting confused ![]()
These are the types of threads the mods should be closing quickly.
Someone please close this?
