Compression Test
If i was to do a compression test on my car which is a 92 gsr and say 1 or 2 cylinders didn’t pass would gettin new all new pisitions help it pass? sorry for the noob question but i wanna go turbo by next summer. and would it be better to get lower comprssion or should i get stock pistion for 6 or 7 psi cause i wanna use it as a daily driver.
if your gonna boost yeah you can go lower if you want
but does lower compression spools up the turbo slower? and does it need low compression pistons for 7psi or should i get oem?
