Create truly glossy ambery oemy looky bumper lightsy! (amber turn signals paint)
I discovered a reliable method, I obviously invented :), to create nearly-OEM-as-if-they-made-OEM-amber-bumper-lights bumper lights. I created these for a friend, and it has proven durable because he polishes the lights when he polishes the car. This tutorial is for advance users only. I will not take any questions that are not related to this tutorial as well. In addition to being BIASED, this is for the only people who have access to many materials. Sorry for being mean - I just don’t want anyone criticizing “shit you could of bought a new bumper light instead of doing this”
Materials:
-Water Soluble Tamiya Clear Red AND Yellow Paint OR Any ACRYLIC Clear Paint at any hobby store
-Small shot glass cup to custom mix your amber
-Paint brush
-800 and 1500 grit sand paper
-Blow dryer
-Any Acrylic Enamel Clear Spray Paint (e.g. Duplicolor, Rustoleum, Krylon) - if you have access to automotive durable clear, go for it.
-Buffing compound and buffing polish (not plastic compound and polish)
  1. Clean and wet sand your lights with 800 grit. It should look evenly hazed. This step creates a “biting” area for the paint.
  2. In the shot glass, put 2 parts of yellow to 1 part red. This will create a nice amber. I tested it out on a spare light to save you people the hassle of finding out that you have a too yellow/red color light. To custom mix your amber, you need to experiment. This is one of the reasons why I did not buy just the orange bottle.
  3. Make sure if you did not buy the Tamiya brand acrylic color clear paint to check if your paint is water soluble. Add a LITTLE water - this is to create an even texture when you paint it on the lights. Mix well.
  4. Paint the lights in one LONG direction THINLY to create an even texture. It should NOT drip or bead on the edges. After the first coat, blow dry it quickly so the paint does not bead up on the edges. Paint and blow dry 4-6 EVEN THIN coats to create the color you want. It should match my sample I did on a spare light. Let it cure for about an hour. There will be lumps but dont worry, the next step will even it out. (You could stop at this step because its already shiny, but it won’t be durable).
  5. Wet sand the lights with 1500 grit LIGHTLY until it is EVEN and HAZED. This step is to prep for the clear coat.
  6. Spray the first coat of clear really really light, it should look bumpy and thin. This is to create a “biting” area for the oncoming coats. Spray 5-6 coats thinly or 3 coats heavily. Sorry no picture…
  7. As you may have already noticed, the clear doesn’t look as even as you thought it would be. “What the fuck happened? Before I put the clear, the lights look super clean?” Well bitch, sand them down again with 1500 sand paper this time. There should not be ANY SHINY SPOTS or LOW CLEAR BUMPS - just one EVEN HAZE - this is critical.
  8. Elbow grease (not really hard to do though) - use a rag and rub that bitch with buffing compound. You’ll instantly see that it will become shiny the minute you rub her curves. Well, its not done yet. Grab the polish and repeat the same step with a lighter material such as a foam sponge or toilet paper.
Care: Remember, these are not plastic no more because you coated them with paint. When you wax and polish your car, run it on these lights too. From what I’ve seen, the lights never yellowed or discolored because when you wax/polish your car it’ll create a thin UV protective film.
Thank you and enjoy.
:clap:
awesome writeup, hope to do this myself next weekend.
wow. i never really knew how to properly paint and clear something until now. this applies to bumper/body paint as well right?
you get 3 snaps in Z formation.
nice work- they look gooood as shit.
and XDEep…that made me laugh out loud.
:up: x 100 That’s a sweet job. :clap:
thats a great writeup. im planning on doing this very very soon.
great job. u seen pro, are you? lol :dance:
I have been trying to get this done to mine, but have not been able to find the tamaya paint.
I know not every hobby store carries Tamiya paint, so any transparent paint will work - even spray on. If you can find the spray on translucent paint, just buy the orange color and then spray clear. The main reason why I wrote this write up is achieving the smooth clean look, which obviously requires sanding and top coating. Just sand with a smooth sand paper and you should be set.
Did you use Tamiya Gloss or Tamiya Flat base paint? Found some paints and thinner at this website for everyone to check out. http://www.ehobbies.com/index.html
Tamiya CLEAR Paint. It should say CLEAR RED OR CLEAR YELLOW OR CLEAR GREEN etc…you should look at it in person instead of guessing if its the one. Like I said, there are many alternatives to clear color paint - theres actually many brands out there such as krylon, vht, duplicolor. As long as your using the same type of paint for the clear (eg. if you buy acrylic colored clear paint make sure you use acrylic clear for the clear coating OR if you use laquer color clear paint make sure you use laquer clear for clear coating) Know what I mean jelly bean? :think:
there’s clear orange, makes it easier then using clear yellow and red
enough coats of clear orange is amber
nice write up but like SOL1D said there is a tamiya clear orange because thats what i used without any clear coat and still looking good.
yes very good write up, i did that once before on a extra set a LONG time ago but the ones on my car now i never did that to because i know that these bumper lights are gonna take a beating from the road and mountains, since are cars are so low anyway, crap is just gonna hit those bumper lights like nothing
so chipping and fading and other harsh things will happen, so no real point in putting to much effort into somethingyour gonna have to redo over and over, but very good write up
only real point i see for this is for car shows or just for meets, i’ve had mines painted for a while and i’ve had other members i’ve painted for, for at least 1 year on there or 2 and there are chips yea but if your not staring at it UP CLOSE you can’t tell the difference at all after car washes or rain or driving for 1 or 2 years still looks great
ive just done my car with these amber color ! i like it :rockon:
Mathiew6 is that a 3 pod A piller gauge holder? If so where did you get it and who makes it? Been lookin for one that holds 3 gauges.
ive got it for 30$ its supposed to came for 89 civic (crx) … so ive worked on the pod a little pid to fit on the car :slight_smile:
ive fitted this pod in my old swift u know! i can do all :clap:
Just had a question, why not just paint it inside instead of outside of the lens? :think:
cuz they dont come apart…
also if you did get them apart and paint the inside, you would still be left with a milky dull outside unless they are brand new.
Thanks for the explain… But mine can come apart easily… (of course OEM one)
Maybe I just need to polish the surface to make it looks like brand new…
