Crvtec90
Been lurking for a while now. Figured Id share sum pics.
91 LS
LS-VTEC Fresh rebuild
RS Type R replica pistons .020 over size
B16 head with mild port cleanup and stock cams
vtec oil pump
ARP Head studs
ARP Rod bolts- rods resized
crank polished
original 91 ls 5 spd with SACHS clutch.
obd1 conversion harness
soon to tune with crome and ostrich emulator
OBX 2 1/4 stainless exhaust system
B&M Fuel pressure regulator
AEM Short ram
Remote start and keyless entry
all power windows, mirrors, sunroof
power door lock actuators and control unit from junkyard car
Eibach ground control with KYB gr2 (Need better struts ) the springs came off a 95 so i dont think theyre correct but they work
5 ZIGEN wheels need a good paint n polish so im running Rota gt3 currently
Bought the car in 2001 for $2600
My coworker giving it a bath when I got it running.
Looks fantastic! Be ready though, durbs will be posting his car with multiple pics soon. I have yet to see a thread with someone posting a blue car without him whoring it.
Good looking out bud.
Wow man very nice build. That blue really pops against the JDM lights.
Car is so low that I cant get my Jack under it. I made a pair of ramps from scrap . 1x6 stacked gradually with a 2x4 on the end for a stopper. I used to just drive up onto a p…air of 2x4 but it didn’t go up as high and it was harder to get them to not move forward when the tire hit them
Picked up a grant ft wheel from the pick-a-part…$25
The kit I had didn’t seem to have enough clearance for the clockspring electric connection for the horn so I guess I need a different mount kit
looking good man… i think mudflaps would really set it off (to match with the black oem front lip)
Ive got the mudflaps somewhere …gotta work on a rear lip too
Temp gauge has been really low so i brought it in for a new 180 degree thermostat
SWEET ass DA my man!!! i am partial to the blue as you can see
[/IMG]
Hey if you own a blue Da you gotta whore it out…lol
Looks clean OP. Welcome to G2IC :slight_smile:
hey were did you order your pistons from?
Ordered off eBay. About a year ago I think.
I needed center caps for my Rota wheels . At 60$ a set I decided to go cheaper . Picked up these from home depot for 1$ each. Ill probably paint them or get stickers .they’re in the electric supply Isle for power boxes or something .
LOL, funniest shit Ive yet to hear come out of your mouth! well maybe not :wink:
clean DA man… thats a very interesting solution to missing wheel caps. im actually curius as to how this is going to turn out.
Thanx BLKACK1 …I just caught ur build this morning…not even with halfway through it yet!
Need some new lug nuts.
Been having idle issues. Thought it was the iac valve… it idled around 1000 rpm and goes to1200 then back down again…not all the time but still too often…found out I picked the wrong t-body gasket. I cant believe it wasn’t worse.
Picked up some black vinyl from the fabric shop and had my buddy help me glue it down smooth to the headliner
