Looking down into the spark plug hole. What you see is the top of the piston at TDC.
Seeing this, I put a section of vacuum hose onto a pick and rested the hose against the top of the shelf that the spark plug would sit on and inserted the pick until it bottomed out against the top of the piston. I placed the pick next to the spark plug and as you can see, there’s not a whole lot of room between the top of the piston and the sparkplug.
Is this possibly correct? I know there are a couple other people out there with CTR pistons in a B17. Can you shed some light?
B17a crank and rods with oversized PCT pistons and OEM head gasket.
Why? The picture shows exactly how much clearance there is between the tip of the plug and the top of the piston with the milled head installed as it would be when the car is running.
It looks like you have about 1/16" of clearance, I dont think you have anything to worry about.
Duy,
is Schu Right in saying .050 for the block? And arw321 u’d seriously trust a pick and rubber hose to determine valve to piston clearance? glad you’re not building my motor.
I could be way off on this, but… If you can use clay for valve to piston clearance, then why can’t you use it for piston dome to plug clearance?
I don’t have the specs in front of me, but there has to be enough clearance to allow for rod stretch. Awhile back I was reading posts from a well known engine guru on H-T, and he didn’t recommend using PCT pistons in anything but a B16B. His recommendation was JDM B16 P30 pistons with different thickness head gaskets / head & block decking to achieve good compression and clearance.
:lol: how about adding a washer to the plug or changing plugs entirely. might change the burn/heat dissipation characteristics tho. or you can take me to pickup my dial indicator i bought and depth gauge.
Lol.
Of course I was basing what I said on the assumption that the measurements were accurate.
And we aren’t talking about piston to valve clearance here.
I have an LS block with CTR pistons and when I clayed my motor I used a piece of clay to also check piston to spark plug clearance, and I probably have just about as much clearance as Archon has.
CTR pistons have huge domes. Of course the clearances are going to be tight.
