Custom Turbo Shopping List
Any turbo people that have put together a custom kit, could you guys give a rundown on parts and their cost?
im looking to boost about 10psi for now, nothing too fancy.
I’m glad you started this thread, cause I to am interested…and was just about to start a thread on this myself
Check this thread out for some info:
http://www.g2ic.com/forums/showthread.php?s=&threadid=5654
are you looking for a custom kit cheaper than a premade one such as drag offers, or are you looking for a no holds barred setup that will support the big hp #'s?
if you are looking for the former, i would say don’t bother as the drag kit is relatively inexpensive considering the convenience & the parts included. group buys from importparts.com add even more value. a cheap custom turbo kit will only cause headaches later…
Reference this past post as well:
http://www.g2ic.com/forums/showthread.php?s=&threadid=5335
I’m building a B16A with 9.1:1 CR and am looking for as much as 16psi, does anyone know of a good custom kit that anyone has done to acheive this much psi? Oh and the motor will be plenty fortified to support that much psi. Thanks, LocalePED
The kit won’t necessarily determine how much boost you can run as much as the type of snail(actual turbocharger) will. The popular T3/T4 Hybrid, will make in upwards of the psi you are seeking. The issue will be, an FMU that can give you safe A/F mixtures upto that point. Standalone Engine Management will be the route to take at those boost levels. HTH
Thanks Rob!..hey, won’t I also need to swap out the Type S blowoff valve for a type H? since the S is for 12psi or less? Thanks, LocalePED
runnin a S on my Talon @ 15 lbs…aint had a problem yet no leaks nothing.
